The inventory detection modules and SCAP checklists are automatically created by the Default SCAP Checklist Processing engine task. You can modify the configuration parameters such as, the collection of test result files, the inventory node name, and the checklist version.
To modify SCAP configuration parameters
All the SCAP checklists available under SCAP_Checklists folder are displayed in the right pane.
The SCAP Configuration dialog appears.
The changes are saved. The changes take effect when the collect task runs next time.
