The Virtualization node and corresponding pane display information about discovered virtual machine guests and virtual machines, which are listed in the Virtual Machine Guests and Virtual Machines subfolders, respectively. Note that the term virtual machines is a generic term, not used just for VMware virtual machines.
Note: The availability of this node depends on whether the asset is a virtual host or not. Additionally, the inventory information available in this pane depends on the host type: HP, IBM, Sun, or VMware.
For example, this pane contains the following columns for Sun virtual hosts:
Displays several portlets with additional information like useful links, tips to work with the objects selected, and other tasks that can be accomplished in this pane. You can use the Customize Information Pane dialog to customize the layout of the portlets on this pane.
Identifies the host name of the virtual machine.
Displays the IP address of the virtual machine.
Displays the state of the virtual machine, for example, Active or Powered Off.
Shows the operating system of the virtual machine.
Identifies the MAC address of the virtual machine.
Displays the virtual host name or ID.
Displays the name of the server hosting the virtual machine.
