You can configure the virtual host inventory collect task to collect RVI data from virtualization servers.
Note: You must have installed Tools on the Hypervisors to collect the complete guest operating system inventory. Also, note that RVI data cannot be collected from Linux virtual machines that are running on Microsoft Hyper-V servers.
The Select new Collect Task type dialog opens.
Note: The Virtual Host Inventory type is available only for assets that have the AMRemoteAgent installed.
The Schedule New Collect Task dialog opens.
The Add the Virtual Host to Configure dialog opens.
Note: You can add only five virtualization servers to a collect task. If the same agent must collect data from more than five virtualization servers, you can define additional collect tasks for the same agent.
Note: Some of the fields are disabled, if the information is not applicable for the selected server type.
Specifies the FQDN of the virtual host you want to inventory.
Specifies the user name of any user on the virtual host. The AM remote agent uses this credential for logging in to the system and collecting inventory.
Specifies the password of the specified user.
Note: You can either use the password and SSH key for authentication. We recommend using SSH keys because they are more secure than plain text passwords.
(IBM HMC) Specifies the host serial number.
Specifies the URL of the Web Service.
The URL takes the following form for VMware vSphere Hypervisor (ESX/ESXi) and VMware vCenter Server:
https://ESXHostFQDNservername/sdk
The URL takes the following form Citrix XenServer
https://XenMasterFQDNservername
The variable in each instance represents the fully qualified host name of the server. Alternatively, an IP address can be given instead of the host name.
By default, this field is auto-populated unless you have changed the RVI Edit URL configuration policy. For more information about this policy, see Asset Management (Administration Console) Policy Group.
Specifies the location of the Secure Shell (SSH) private key. Provide an SSH key location for a Linux/UNIX host only if the key is not in the default location.
Note: Provide an empty passphrase when generating the SSH key.
Specifies whether remote inventory collection is enabled. Verify that this option is selected.
Note: The Filter tab is displayed only for VMware vCenter Server and Citrix XenServer.
The filter is added to the collect task.
The collect task runs at the agent computer at the next scheduled runtime and collects the RVI data from the selected servers.
Note: You can link the virtual host inventory collect task only to other agents of the same OS class. For example, a virtual host inventory collect task that is created for a Windows agent can be linked only to other Windows agents.
