Previous Topic: Reset a Value to DefaultNext Topic: Unseal a Policy
Seal a Policy
A policy must be sealed before you can assign the configuration to an asset. An unsealed configuration is indicated by a computer icon with a section reference mark: Unsealed Policy Icon
To seal a policy
  1. Right-click an unsealed policy in the tree view or in the Configuration Policy pane.
    A context menu appears.
  2. Select Seal from the context menu, or click Seal in the Tasks portlet of the Configuration Policy pane.
    The policy is sealed and marked with a padlock icon.
More information:
Sealed and Unsealed Policies
