Previous Topic: Modify a Policy Using the Setting Properties DialogNext Topic: Configuration Policy Setting Status
Modify Settings (Tables)
Use the Modify Settings dialog to modify the policy settings for table structures, such as DTS share definitions.
Note: The Data Transport Service (DTS) is not available for some CA component plug-ins and applications.
To modify a policy
Note: Before you can modify a policy, you must unseal it.
  1. Right-click a parameter and choose Setting Properties from the context menu.
    If the policy has a table structure, the Modify Settings dialog appears and displays the policy name, description, and the rows and values currently defined to the configuration policy.
  2. Click Modify to change the existing values of the table structure.
    Alternatively, double-click a table entry to change its value.
  3. (Optional) Click Add Row to add a new row to the current table structure.
  4. (Optional) Select a row and click Delete Row to delete the selected row.
  5. Click OK.
    Your changes to the table structure are saved.
More information:
Sealed and Unsealed Policies
Setting Parameter Values
