Previous Topic: Seal a PolicyNext Topic: Policy Updates
Unseal a Policy
You must unseal a policy before you can modify its configuration settings. A sealed policy is marked by a padlock icon: Sealed Policy Icon
To unseal a policy
  1. Right-click a sealed policy in the tree view or in the Configuration Policy pane.
    A context menu opens.
  2. Select Un-Seal from the context menu, or click Unseal in the Tasks portlet of the Configuration Policy pane.
    The policy is unsealed and marked with a computer icon with a section reference mark.
More information:
Sealed and Unsealed Policies
