The New Action dialog lets you select an action type that you want to add to the policy. The number of actions available depends on the policy type.
This dialog has the following field:
Specifies the action type to be added to the policy. From the drop-down list, select the action type and click OK.
Depending on the action type selected the Add Notification Action dialog or the appropriate Configure Policy Actions dialog appears. Either dialog lets you specify an action to take effect on a violated policy.
