Asset Management › Policies › Query Based › Policy Designer Dialog › Policy Designer Dialog: Add Action › Add Action: Add to Group
You can add the asset that is violating the policy to the specified group.
The Configure Policy Actions dialog for this policy contains the following fields and check box:
- Group
Lists the existing group and lets you select the group to which the asset will be added to.
- Remove from group when policy is no longer met
Removes the asset from the group when the asset complies with the policy.
- Perform action when Asset no longer violates Policy
Evaluates the policy as defined during policy creation.
When you select this check box, the following happens when an asset no longer complies with the policy:
- The asset is no longer displayed in the Violators list.
- The policy is removed from the violated policies list in the Home page of the asset and the domain home page.
- The asset icon changes to the default icon (when it does not violate another policy).
- The configured action will be initiated.
