Previous Topic: Add Action: System Event LogNext Topic: Add Action: SNMP Trap
Add Action: Unicenter Event Log
You can log the policy notification in the Unicenter Event Console. You can access the event console from Tools, Unicenter, Event Console menu in the DSM Explorer.
Note: The Engine generates the log entry on the computer on which it is installed.
The Configure Policy Actions dialog for this policy contains the following fields and check box:
Enter message
Defines the text to be logged in the Unicenter Event Log.
Macro
Specifies the macro that you want to add to the notification message. You can add any number of macros to the message.
Add
Adds the selected macro to the message.
Perform action when Asset no longer violates Policy
Evaluates the policy as defined during policy creation.
When you select this check box, the following happens when an asset no longer complies with the policy:
