Once a policy has been created, the actions associated with this policy are displayed in the Actions pane. These actions are triggered as soon as an asset violates a policy.
Note: Some of the actions take effect when the asset violates the policy, and some take place when the asset no longer violates the policy.
The Actions pane contains the following columns:
Shows the current actions selected for this policy. Depending on the type of policy selected, different actions are available.
Shows the order in which the actions must take place.
Indicates the reason for the action (for example, violation).
Shows the actual contents of the actions.
Select Add Actions from the Tasks section to open the Add Action dialog and specify any additional actions.
