The Power Settings pane displays the information about the power settings, such as support hibernation, and Uninterruptible Power Supply (UPS) presence, policies set for the power settings, and power management attributes for Green IT Assessment.
This pane includes the following node:
Includes the following power management attributes of the assets for Green IT Assessment. If the system has a battery present, the DC settings are shown. There is a DC setting for each AC setting, for example, DC – Monitor Timeout. If the attributes are not retrieved, the status is displayed as Unknown in the user interface.
Note: Windows does not store the power scheme name along with the currently in use power scheme settings on Windows versions earlier than Windows Vista and Windows 2008. On versions prior to Windows Vista and Windows 2008, the power scheme name is stored on the user login, provided the user has a permission to change the power scheme. If a privileged user logs in, changes the power scheme to one with a different name, logs off, and then does not log on again before an asset scan is done, the power scheme name that is stored will be incorrect.
The Power Policy node also includes the AC Policy group that contains the following parameters:
And, groups within the AC Policy group contain the following items:
The parameter timeout value of 00:00:00 signifies Never, which means that the timeout will never occur. However, any other time is the actual timeout value in the form of hh:mm:ss (hours:minutes:seconds), for example, 00:10:00 signifies 10 minutes timeout.
Note: This inventory information is collected by the General Inventory module and is available only if you have installed asset management.
The following columns display the value for each of the preceding attributes:
Displays the scanned inventory item such as total memory and speed.
Shows the value of the items.
Shows the last modified value.
Shows the date when the item was last modified.
Note: You can show or hide these columns.
