Previous Topic: External DevicesNext Topic: Power Settings
Input Devices
The Input Devices pane displays the information about the input devices such as keyboards or pointing devices.
Note: This inventory information is collected by the General Inventory module and is available only if you have installed asset management.
This pane contains the following columns:
The following columns display the value for each of the preceding attributes:
Attribute
Displays the scanned inventory item such as total memory and speed.
Value
Shows the value of the items.
Previous Value
Shows the last modified value.
Date
Shows the date when the item was last modified.
Note: You can show or hide these columns.
