The External Devices pane displays the information about the external devices such as monitors and printers attached to the computer asset.
Note: This inventory information is collected by the General Inventory module and is available only if you have installed asset management.
This pane contains the following columns:
Displays the information about the computer monitor.
Note: The width and height of the display is shown as 0 in some cases, especially when the graphical driver does not supply this information.
The following columns display the value for each of the preceding attributes:
Displays the scanned inventory item such as total memory and speed.
Shows the value of the items.
Shows the last modified value.
Shows the date when the item was last modified.
Note: You can show or hide these columns.
