Use the Group dialog to select the applications that you want the current asset to have Power rights or VIP Unit rights to.
Note: Available categories and options may vary depending on the products and components installed.
Specifies the application, which the asset can access as Power or VIP Unit.
Selects the level of access to the applications added to the group.
The Power and VIP Units are used by the license management scheme, that dictates how units are assigned licenses, put on hold in a license queue when no licenses are currently available, or both.
Launches an application and therefore does not have entries created in the software usage-site directory.
Places the VIP unit in a queue by the license management scheme, if there are no licenses available. To manage VIP units, files corresponding to the users are created in the application-software usage directories. When a user obtains a license, a special license file is created in the directory, and correspondingly when the user is queued for a license, a special queue file is.
Adds the application to the list of applications. The application is marked with the access level.
Deletes the selected application from the list of applications under the asset name. The application is removed from the list.
