Previous Topic: Software Rights Dialog - GroupNext Topic: History - Group Folder
Software Rights Dialog—Asset
Use the Asset dialog to select the applications that you want the current asset to have Power rights or VIP Unit rights to.
Note: Available categories and options may vary depending on the products and components installed.
Application
Selects the application which the asset can access as Power or VIP Unit.
Access Level
Selects the level of access to the applications added to the group.
The Power and VIP Units are used by the license management scheme that dictates how units are assigned licenses or put on hold in a license queue when no licenses are currently available or both.
Power Unit
Launches an application and therefore does not have entries created in the software usage-site directory.
VIP Unit
Places the VIP unit in a queue, if there are no licenses available. To manage VIP units, files corresponding to the users are created in the application-software usage directories. When a user obtains a license, a special license file is created in the directory, and correspondingly when the user is queued for a license, a special queue file is.
Add
Adds the selected application to the list of applications. The application is marked with the access level.
Delete
Deletes the selected application from the list of applications. The application is removed from the list.
More information:
Asset Context Menu Options
