Various menu options are available on asset context menus for all of the individual assets listed under the All Computers, All User Profiles, and All User Accounts groups.
The asset context menus contain the following options:
Opens the selected asset in a separate window.
Copies the selected asset and lets you paste it in another folder.
Pastes various objects like Configuration Policies, OS Image, Software Package, and so on. You should first copy the object and then paste it in the asset.
Opens the New Group dialog where you can create a new group of assets based on those selected.
Deletes the asset after you confirm the deletion.
Sends a wake-on-LAN message to the computer and powers up the computer only if the Wake-on-LAN (WOL) feature is enabled.
Note: For detailed information about WOL functionality in the DSM Explorer and Remote Control, see the DSM Explorer Help and the Remote Control Administration Guide.
Opens Change Scalability Server window where you can select an alternative scalability server within the respective domain.
Runs the diagnosing task and displays the diagnostic information file in the Internet Explorer.
Opens the CA SDM Create New Ticket window in the browser and automatically fills in the Asset field with the selected asset name.
Note: The Create Service Desk ticket option is available only if you have enabled the CA Service Desk integration. For more information, see Service Desk Integration Policy Group under Configuration Policy in the DSM Explorer Help.
Note: Available categories and options may vary depending on the products and components installed.
The Asset Jobs option provides access to the following sub-options:
Opens the New Job Wizard that guides you through the creation of a new job.
Opens the Select Asset Jobs dialog where you can select jobs that you want to add and deploy to the current unit.
Opens the Asset Job Check dialog where you can select the options the asset management agent uses to perform its currently scheduled asset jobs and modules.
The following menu item is available only if you have installed the OSIM plug-in:
Runs the OS Installation wizard that guides you through the steps required to setup a new OS installation on selected computers.
The following menu items are available only if you have installed the remote control plug-in:
This menu has the following menu options that are related to remote control:
Opens the Select User dialog and, in turn, the Effective Remote Control Permissions dialog, which displays the effective permissions for the selected user on this computer.
Opens the Connection Addresses dialog for modifying the addresses of a remote computer. (Only available at the domain manager level.)
Lets you send special commands to the remote computer. Valid options are: Lock, Unlock, and Reboot. (Only available at the domain manager level.)
Opens the Connection Settings dialog, letting you take control of that asset and start a remote control session using the remote control viewer component.
Note: For more information, see the Remote Control Viewer Help.
The following menu items are available only if you have installed the software delivery plug-in.
This menu has the following sub-menus that are related to software delivery:
Runs the Deploy Software Package wizard.
Runs the software delivery job check.
Attaches or detaches a CCS job calendar.
Selects the download method.
Selects the Reinstall After Crash (RAC) Policy.
Runs the Deploy Software Package wizard and Create Software Policy wizard that let you deploy and create software policies on target installations.
Opens the Object Permissions dialog.
Opens the Software Rights for asset dialog.
Opens the Properties dialog of the selected unit. The tabs available on the Properties dialog depend on the asset type (Computer, User Account, or User Profile).
