The DSM Explorer › Computers and Users Folder › All Computers › Computer Name Pane › Asset Context Menu Options › Run the Asset Job Check
You can choose the options available on the Asset Job Check dialog for running the job check. When you select the options, the asset management agent starts immediately to run the collect tasks and jobs configured on the asset.
Note: Available categories and options may vary depending on the products and components installed.
To run the asset job check
- Right-click the computer on which you want to run the asset job, and select Asset Job, Asset Job Check.
The Asset Job Check dialog appears.
- Select the Rescan Hardware Inventory check box to run the hardware inventory collect tasks configured on the asset.
- Select the Rescan Software Inventory check box to run the software discovery collect tasks configured on the asset.
- Select the Re-collect check box to collect and send all the inventory information. By default, after collecting the inventory information, the agent sends only the differential values, that is, the values that have changed since the previous scan. This reduces network traffic. However, if you want the agent to send all the information, select this option.
- Click OK.
The agent runs on the asset to perform the configured jobs.
More information:
