CMP Editor › Using CMP Editor Functions
The CMP Editor functions let you work on the compressed files contained in the files.cmp and ufiles.cmp archive files; including adding and deleting files, modifying file contents and properties, and starting or opening files.
More information:
Export Files from the CMP File
Explore Files from the CMP File
Undo Actions on Files in the CMP File
Sort Contents of the CMP File Window
Exit CMP Editor
Start or Open Files from the CMP File
Save File Changes in CMP File
Modify Contents of Files in the CMP File
Undo All Actions on Files in the CMP File
Add Files to the CMP File
Delete Files in the CMP File
Select a New Destination Directory
Customize the Directory Path of a File in the CMP File
Edit Properties of Files in the CMP File
