CMP Editor › Using CMP Editor Functions › Edit Properties of Files in the CMP File › Customize the Directory Path of a File in the CMP File
You can customize the current directory path of a file in the CMP File for a more flexible use by inserting an SXP parameter at the beginning of the directory path. You can dynamically assign a value to this SXP parameter.
The SXP parameter can only replace the drive letter or another existing SXP parameter at the beginning of the directory path.
To customize the directory path of a file in the CMP File
- Do one of the following on the Directory tab of the Properties dialog:
- Edit the displayed directory path manually.
- Select one of the available SXP parameters from the selection list.
- Click Apply to confirm the changes without leaving the Properties dialog, or click OK to apply the changes and close the Properties dialog.
