You can undo the previous and not-yet-saved actions on files in the CMP File. The Undo function applies to files that have been marked for adding, deleting, or modifying.
To undo the previous and not-yet-saved actions on files in the CMP File
After the modifications on the selected files are undone, all file status symbols in the left margin of the CMP File window are reset to the File in hibernation symbol
