The toolbar options allow quick access to relevant CMP Editor functions and features through toolbar buttons, as follows:
Saves all changes made to all files in the CMP File.
Adds files to the CMP File.
Removes selected files from the CMP File.
Copies and extracts selected files from the CMP File in a working directory. The files still remain in the CMP File.
Sets or modifies options, attributes, or the directory path for the selected files in the CMP File.
Modifies contents of selected files from the CMP File.
Opens or starts selected files depending on their file extension. (Only available when using the Add File or Modify Contents function.)
Opens an Explorer window for each selected file. The Explorer window contains the working directory of the file. (Only available when using the Add File or Modify Contents function.)
Opens the CMP Editor online help.
