The methods of this section are valid for enterprise manager only.
Note: The terminology of CA IT Client Manager has changed in comparison with Unicenter Software Delivery 4.0. The SD "area" is equivalent to the CA ITCM "domain", while the SD "domain" is equivalent to a CA ITCM group of domains.
Nevertheless for compatibility reasons the terminology, command, and parameter names of the CLI have not changed!
To avoid any ambiguity, in the subsequent sections an area (a domain in the terminology of CA IT Client Manager) is mentioned as a "CA ITCM domain", and a domain (a domain group in the terminology of CA IT Client Manager) is mentioned as "CA ITCM domain group".
The CA ITCM domains are handled by the area command of the CLI and the CA ITCM domain groups by the domain command of the CLI.
This section contains the following topics:
add—Add Domains to Domain Groups
addSubDomains—Add Domain Groups to Domain Groups
listMembership—List Domain Supergroups
modify—Modify Domain Group Attributes
remove—Remove Domains from Domain Groups
removeSubdomains—Remove Domain Groups from Domain Groups
