This action creates a new CA ITCM domain group. The CA ITCM domain group can be populated with CA ITCM domains during creation.
domain action=create name=domain_name
[comment=comment]
[{area=area_name}|addAll]
[superDomain=super_domain_name]
[InheritPerms[={y|n}]]
Specifies the name of a CA ITCM domain group. It will be created.
Specifies a comment.
Specifies the name of a CA ITCM domain to the CA ITCM domain group to be created.
The parameter can be coded more than once to add a list of CA ITCM domains.
This parameter should not be coded if "addAll" is coded.
Add all registered CA ITCM domains to the CA ITCM domain group to be created.
This parameter should not be coded if the parameter "area" is coded.
Specifies the name of an existing CA ITCM domain group that might contain other CA ITCM domain groups . The CA ITCM domain group to be created will become a subgroup of this CA ITCM domain super group.
If this parameter is not coded, the CA ITCM domain group is placed at the folder named "Domains".
This parameter specifies if the group being created inherits security permissions or not.
If “InheritPerms” or “InheritPerms=y” is coded then the specified group will inherit permissions to it members and becomes a security group.
If “InheritPerms=n” is coded then the specified group will not inherit permissions to its members and therefore is no security group.
Default: InheritPerms=y .
Note: The action create allows you to create empty CA ITCM domain groups, in other words, neither "area" nor "addAll" have to be coded with the command. CA ITCM domains can be assigned later with the "add" action.
