This action modifies the attributes of a CA ITCM domain group.
domain action=modify name=domain_name
[newName=new_domain_name]
[InheritPerms[={y|n}]]
[comment=comment]
This optional parameter specifies if the group being modified is a security group or not.
If “InheritPerms=n” is coded then the specified group will not inherit permissions to its members and therefore is no security group any longer.
If “InheritPerms” or “InheritPerms=y” is coded then the specified group will inherit permissions to it members and therefore becomes a security group.
If the parameter is not coded then the permission inheritance settings of the group are not changed.
Specifies the name of a CA ITCM domain group to be modified.
Specifies the new name of the CA ITCM domain group.
Specifies a comment.
Note: To erase an existing comment, enter the empty string ("").
