Previous Topic: ExampleNext Topic: Example 1
removeSubdomains—Remove Domain Groups from Domain Groups
This action removes CA ITCM domain groups as CA ITCM domain groups from the specified CA ITCM domain group.
domain action=removeSubdomains [name=domain_name}]
{domain=domain_name}
name
Specifies the name of a CA ITCM domain group which must exist and from which the CA ITCM domain subgroups will be removed.
If not coded the CA ITCM domain subgroups are removed from the top level folder "Domains".
domain
Specifies the name of a CA ITCM domain group which must exist and which will be removed as a CA ITCM domain subgroup from the CA ITCM domain group specified in the "name" parameter.
The parameter can be coded more than once to remove a list of CA ITCM domain subgroups.
Note: A remove does not necessarily mean that the CA ITCM domain subgroup to be removed will be deleted. It will only be removed from a list of CA ITCM domain subgroups associated to the specified CA ITCM domain supergroup.
If a CA ITCM domain subgroup "A" is removed from a CA ITCM domain group "B" and if "B" is the only supergroup containing "A", then the remove will fail. "B" can only be deleted.
