Previous Topic: Script File: Download Primer <Platform> SectionNext Topic: Compressing and Uncompressing Files for Download
Script File: Download <Platform> Section
For each supported platform the script file contains a Download <Platform> section. This section describes for the Web Launcher what and how to download files for the specified platform. The following is an example for the Windows platform.
Example: Download <Platform> Section
[Download_Windows]
Method=webservice
Executable=cmNriAgent.exe
CommandLine=-script .\adv.ini
Files=2
File1=basic_heuristic.exe
File2=w0000001.zml,w0000001.xml
The following table includes the parameters available in the Download <Platform> section:
Parameter
Description
Method
Defines the method to use to download the files. Currently only "webservice" is supported.
Executable
Defines the name of the executable the primer should execute when all files are downloaded.
CommandLine
Specifies the command line to use when executing Executable.
Files
Indicates the number of files to download.
FileX
Specifies the name of the file to download. Specify uncompressed name after the comma.
Note: For more information, see Compressing and Uncompressing Files for Download.
More information:
Script File: General Section
Script File: Advanced Section
