Some files will be fairly large and could take a considerable time to download. For this reason it is possible to compress and uncompress files. To compress files, the def_inf.exe tool must be used. To have the NRI Primer uncompress files after downloading, the compressed name and uncompressed name must both be specified on the "FileX" line, separated by a comma.
Example
File2=w0000001.zml,w0000001.xml
In this example, the file "w0000001.zml" is downloaded by the NRI Primer and then expanded to a file named "w0000001.xml". Both files are removed when cleaning the work area.
