Previous Topic: Script File: General SectionNext Topic: Script File: Platforms Section
Script File: Advanced Section
The Advanced section currently contains only the following item.
Example: Advanced Section
[Advanced]
KeepWorkArea=0/1
The following table includes the parameters available in the Advanced section:
Parameter
Description
KeepWorkArea
Default value is 0. If the value is set to 1, the NRI Primer does not remove all downloaded files. Generated inventory files are not deleted as well.
