For each supported platform the script file may contain a Download Primer <Platform> section. This section lists some primer-specific files that must be downloaded for the primer to work.
Example: Download Primer <Platform> Section
[Download_Primer_Windows] Files=2 File1=def_inf.exe File2=zlib1.dll
The following table includes the parameters available in the Download Primer <Platform> section:
Parameter |
Description |
Files |
Specifies the number of files to download. |
FileX |
Specifies the name of the file to download. |
Note: The files listed in the example above are the files necessary to decompress files that have been compressed.
