Using the Eventlist Interface › Customizing Eventlist › Change the Way Eventlist Works › Indicating That Eventlist is to Exit When Console Manager is Shut Down
To indicate that Eventlist is to exit when Console Manager is shut down:
- Pull down the Options menu and choose the General ... menu item.
- The General Settings dialog box is displayed (see the previous figure).
- Select Exit on Console Manager Shutdown.
- Click OK.
- Pull down the Options menu and choose Save Options to save your settings.
Copyright © 2010 CA.
