Previous Topic: Scenarios for Filtering EventsNext Topic: Filtering for a Specific Event Priority
Filtering for a Specific Event Class
This scenario describes how to receive events of a specific class.
The Scenario
A security administrator needs to know about all events that have the class Security on all systems. The administrator wants the events to be sent by an eventlist to the workstation
admin.reo.dec.com.
One action, one filter and one dispatch are required. The action will use the eventlist action routine to dispatch the events.
Assume that the events, classes and serviced systems have already been created in the configuration database, and that the DECwindows Motif transport is TCP/IP.
The Solution
To set up the filtering mechanism for a specific event class, you would do the following:
Step
Action
For Command Line Interface
For C3 Interface
1.
Start the configuration editor
Starting the Configuration Editor in the chapter Modifying the Configuration Database
2.
Create an action with the following attributes:
Name Enter Security
Information Enter Security events on all systems
Command Enter: CONSOLE$EVENTLIST
Action Type Select the “ALL events and EACH userdata item” option
Parameters
To Pass Select Userdata only, deselect all others
To Action
Adding Actions in the chapter Setting Up the ENS Components
3.
Create a filter with the following attributes:
Name Enter Security
Events Deselect All Events
Classes1 Deselect All Classes, and select only the Security class
Systems Select All Systems
Groups Select All Groups
Subsystems Select All Subsystems
Priorities Select All Priorities
Adding Filters and Dispatches in the chapter Setting Up the ENS Components
Adding Filters in the chapter Setting Up the ENS Components
4.
Create a dispatch for the filter with the following attributes:
Action to Enter Security
dispatch
Userdata Enter admin.reo.dec.com 0 0 tcpip
Select Execute at all Times on All Days
Adding Dispatches for Your Actions in the chapter Setting Up the ENS Components
Compare these fields with the corresponding fields in the scenario described in the following section, Filtering for a Specific Event Priority. These two fields are the major functional differences between this scenario and the scenario described in Filtering for a Specific Event Priority.
