Previous Topic: Filtering for a Specific Event ClassNext Topic: Filtering Events from a Group of Systems Depending on the Time
Filtering for a Specific Event Priority
This scenario describes how to receive events of a specific priority.
The Scenario
A managing director needs to know about all critical events. The MD wants the events to be sent by an eventlist to the workstation theboss.reo.dec.com.
One action, one filter and one dispatch are required. The action will use the eventlist action routine to dispatch the events.
Assume that the events, classes and serviced systems have already been created in the configuration database, and that the DECwindows Motif transport is TCP/IP.
The Solution
To set up the filtering mechanism for a specific event priority, do the following:
Step
Action
For Command Line Interface
For C3 Interface
1.
Start the configuration editor
Starting the Configuration Editor in Chapter 4, “Modifying the Configuration Database”
2.
Create an action with the following attributes:
Name Enter Critical
Information Enter Critical events on all systems
Command Enter: CONSOLE$EVENTLIST
Action Type Select the “ALL events and EACH userdata item” option
Parameters
To Pass Select Userdata only, deselect all others
To Action
Adding Actions in Chapter 11, “Setting Up the ENS Components”
3.
Create a filter with the following attributes:
Name Enter Critical
Events Select All Events
Classes1 Select All Classes,
Systems Select All Systems
Groups Select All Groups
Subsystems Select All Subsystems
Priorities Deselect All Priorities. In the Priorities dialog box, select Critical, and deselect all the other priorities
Adding Filters and Dispatches in Chapter 11, “Setting Up the ENS Components”
Adding Filters in Chapter 11, “Setting Up the ENS Components”
4.
Create a dispatch for the filter with the following attributes:
Action to Enter Critical
dispatch
Userdata Enter.theboss reo.dec.com 0 0 tcpip
Select Execute at all Times on All Days
Adding Dispatches for Your Actions in Chapter 11, “Setting Up the ENS Components”
1Compare these fields with the corresponding fields in the scenario described in Filtering for a Specific Event Class. These two fields are the major functional differences between this scenario and the scenario described in Filtering for a Specific Event Class.
