See the chapter Understanding ENS for information about actions.
To add an action
$ CONSOLE EDIT /INTERFACE=character_cell
CM Edit> add action
Action name: your action
Information: your description
Command: your_action.com
Note: You must include the appropriate file extension on the corresponding action routine, for example YOUR_ACTION.COM for a command file.
Action types may be one of the following :- 1 = Activate once for EACH event and EACH userdata item 2 = Activate once for ALL events and ALL userdata items 3 = Activate once for ALL events and EACH userdata item Action Type ? (1:) 1
Pass all Arguments? [Y/N] (Y:) N
Pass Event Name? [Y/N] (Y:) Y
Pass Event Time? [Y/N] (Y:) N
Pass Event Class? [Y/N] (Y:) N
Pass Event Information? [Y/N] (Y:) Y
Pass Event Text? [Y/N] (Y:) N
Pass Event Priority? [Y/N] (Y:) N
Pass system that generated event? [Y/N] (Y:) N
Pass subsystem that generated event? [Y/N] (Y:) N
Pass source of event (application? [Y/N] (Y):) N
Pass User-defined data? [Y/N] (Y:) N
OK to add? [Y/N] (Y:) Y
The following is an example of what you see on your screen:
Database contains NO verification errors CM Edit> add action Action name: your action Information: your description Command: your_action.com Action types may be one of the following :- 1 = Activate once for EACH event and EACH userdata item 2 = Activate once for ALL events and ALL userdata items 3 = Activate once for ALL events and EACH userdata item Action Type ? (1:) 1 Pass all Arguments? [Y/N] (Y:) N Pass Event Name? [Y/N] (Y:) Y Pass Event Time? [Y/N] (Y:) N Pass Event Class? [Y/N] (Y:) N Pass Event Information? [Y/N] (Y:) Y Pass Event Text? [Y/N] (Y:) Y Pass Event Priority? [Y/N] (Y:) N Pass system which generated event? [Y/N] (Y:) N Pass subsystem which generated event? [Y/N] (Y:) N Pass source of event (application? [Y/N] (Y):) N Pass User-defined data? [Y/N] (n:) N OK to add? [Y/N] (Y:) Y
Copyright © 2010 CA.
