Previous Topic: Add ActionsNext Topic: Using the DECwindows Interface to the Configuration Editor
Modifying and Deleting Actions
Before you can modify or delete entries in the configuration database, you must have the Edit Configuration data privilege set in your user entry.
To modify an action, use the modify action command.
To delete an action, use the delete action command.
Note: Any changes you make to the predefined action definitions may not be preserved when your Console Manager installation is upgraded with new releases.
