Previous Topic: Modifying and Deleting FiltersNext Topic: Add Actions
Modifying and Deleting Dispatches for Filters
If you want to modify the dispatch for a filter, you must delete the filter, and recreate the filter with the new dispatch (see the previous section, Adding Filters and Dispatches.)
If you want to delete the dispatch for a filter, then modify the filter, and enter the name of the action to be removed at the following prompt:
Enter action names to remove. (?=list)
 Remove Action (CR=end:)
Accept the defaults for all other prompts.
