Before you can modify or delete entries in the configuration database, you must have the Edit Configuration data privilege set in your user entry.
To modify a filter, use the modify filter command. You can change only a subset of the filter attributes. The attributes that can be modified are:
The steps for modifying a filter are similar to those described in the previous section, Adding Filters and Dispatches.
To delete a filter, use the delete filter command.
Copyright © 2010 CA.
