Customizing Console Manager › Customizing Your C3 Display › Displaying the Group, System and Peripheral Labels
You can automatically display the name of your groups, systems or peripherals on the C3 interface. The position of the label is determined by the Label Placement selection in the System Icon dialog box.
To display labels on your C3 interface
- Click the mode change button to change to Edit mode.
- Pull down the Options menu and choose the On submenu item from the All Labels menu. This displays the labels to all the icons representing the groups, serviced systems and peripherals.
To hide all labels on the display, pull down the Options menu and choose the Off submenu item from the All Labels menu.
- After finishing all your edits, click the mode change button to change back to Interactive mode.
- To save your edits, pull down the Options menu and choose the Save menu item to save the changes you have made.
Copyright © 2010 CA.
