Previous Topic: Modifying Icons Representing Serviced SystemsNext Topic: Displaying the Group, System and Peripheral Labels
Modifying Icons Representing Groups
The groups you have access to in the configuration database are shown on the C3 display.
To change the icon outline or description
  1. Click the mode change button to change to Edit mode.
  2. Click the right mouse button on the icon representing the group you want to change.
  3. Choose Modify from the popup menu displayed. This displays the Group Icon dialog box.
  4. Change the required fields in the dialog box.
  5. After finishing all your edits, click OK.
  6. Click the mode change button to change back to Interactive mode.
  7. To save your edits, pull down the Options menu and choose the Save menu item to save the changes you have made.
