Customizing Console Manager › Customizing Your C3 Display › Modifying Icons Representing Peripherals
To change the icon's picture, name, and description
- Click the mode change button to change to Edit mode.
- Click the right mouse button on the icon representing the peripheral you want to change.
- Choose Modify from the menu displayed. This displays the Peripheral Icon dialog box.
- Change the required fields in the dialog box and click OK.
- After finishing all your edits, click the mode change button to change back to Interactive mode.
- To save your edits, pull down the Options menu and choose the Save menu item to save the changes you have made.
You can delete icons representing peripherals from the display by clicking on Delete instead of Modify.
Copyright © 2010 CA.
