Previous Topic: Setting the DECterm Resource File Name for a Serviced SystemNext Topic: Add Icons Representing Peripherals
Moving Icons
To move the icons representing the serviced systems and peripherals on your display
  1. Click the mode change button to change to Edit mode.
  2. Press and hold the left mouse button on the icon you wish to move, drag it to its new position and release the left mouse button.
  3. After finishing all your edits, click the mode change button to change back to Interactive mode.
  4. To save your edits, pull down the Options menu and choose the Save menu item to save the changes you have made.
Compare the figure in the section, How to Set Up a Common Console Manager C3 View, earlier in this chapter with the figure found in section, The Group Window, in Chapter 7, “Using Console Manager From the Command Line Interface,” to see how icons can be repositioned.
