Customizing Console Manager › Customizing Your C3 Display › Setting the DECterm Resource File Name for a Serviced System
You can specify a DECterm resource file for each serviced system, to be used when you:
- Connect to the console of the serviced system
- Run the monitor interface for the serviced system
- Log in to the serviced system from the C3 interface.
To set the DECterm resource file for a serviced system
- Click the mode change button to change to Edit mode.
- Click the right mouse button on the system icon, and select Modify from the popup menu. The Modify System dialog box is displayed (see the figure in Setting Control Keys, earlier in this chapter).
- Enter the name of the DECterm resource file you want to use in the DECterm resource filename field.
- Click OK.
- Click the mode change button to change back to Interactive mode.
- To save your edits, pull down the Options menu and choose the Save menu item to save the changes you have made.
Copyright © 2010 CA.
