Customizing Console Manager › Customizing Your C3 Display › Setting Startup Options
You can set up your C3 display to do any of the following at startup:
- Start the event list window.
- Iconify the C3 display.
- Set the double click action on a system icon to either start a connect to console session, or perform a show history.
- Set the icon color change to either the latest event or the highest event priority received.
To set startup options:
- Choose the General ... menu item from the Options pull down menu. This displays the C3 General Options dialog box.
- Click the items you require, and then on OK.
- To save your edits, pull down the Options menu and choose the Save menu item to save the changes you have made.
Copyright © 2010 CA.
