Previous Topic: Customizing Your C3 DisplayNext Topic: Setting Startup Options
How To Set Up a Common Console Management C3 View
By default, each user's C3 display can be customized independently of other users' displays. Each user's settings are stored in their copy of the customization file (see The Customization File, earlier in this chapter).
You can set up a common interface for all users as follows:
Before starting the C3 interface, define the logical name CONSOLE$USER_DEFAULTS to point to a directory that contains the common CONSOLE$C3.DAT resource file. The logical definition may be placed in the LOGIN.COM file for each user sharing a C3 configuration view:
$ DEFINE CONSOLE$USER_DEFAULTS directory_specification
Various files used by other user interfaces must also be moved to the common directory as listed in the following table.
Interface
Files Affected
C3
CONSOLE$C3.DAT
CONSOLE$C3_username_MSG.LOG
Connect and Monitor
CONSOLE$MONITOR_INIT.DAT
CONSOLE$command.SCRIPT
Eventlist 1
CONSOLE$EVENTLIST.DAT
1When you run Eventlist from the command line.
