Previous Topic: Status Values Returned by the Dialog CommandNext Topic: Unlocking a Console Being Used by Another User
Creating a Dialog Script
You can use one or more of the commands shown in the following table in a dialog script.
Command
Description
BREAK
Sends the halt sequence or a break signal to the console.
HALT
RATE
Sets the period of time in seconds between which the dialog should pause before executing the next SEND command.
SEND
Sends a specified string to the console.
SPEED
Sets the time, in milliseconds, that the dialog is to pause before sending the next character.
UNLOCK
Disconnects a user currently connected to the system the dialog procedure is running on.
WAIT
Stalls for a timeout number of seconds, or until the quoted string occurs on the console line. If a WAIT times out without the string being seen, the dialog procedure exits.
The following qualifiers let DIALOG work correctly on some systems. By default, the string transmitted by a SEND command is terminated by a carriage Enter/new line pair.
/NORETURN
Specifies that the string transmitted by a SEND command should not be terminated by a carriage Enter (CR).
/NONEWLINE
Specifies that the string transmitted by a SEND command should not be terminated by a new line (LF) character.
See the appendix Sample DIALOG File for an example of dialog procedure.
