The dialog command does not display a status value when it exits. To find the status value returned, and its meaning, do the following:
$ SHOW SYMBOL $STATUS
Status Value (Hex.) |
Meaning of the Status |
10000065 |
Success |
10000066 |
A bad dialog file was specified |
10000068 |
A bad system name was specified |
1000006A |
Unable to connect to the serviced system |
1000006C |
The system console is locked by another user |
1000006E |
You do not have UNLOCK privilege |
10000070 |
You do not have BREAK privilege |
10000072 |
Invalid syntax for WAIT command |
10000074 |
Timeout of WAIT command |
10000076 |
Dialog file has syntax error |
10000078 |
Unable to read the Console Manager configuration file |
1000007A |
The serviced system is being archived |
1000007C |
Dialog could not check the status of the serviced system |
Copyright © 2010 CA.
