Previous Topic: EnvironmentNext Topic: Console Manager Tuning
Sample DIALOG File
The following example shows an example dialog procedure.
Note: We do not recommend embedding passwords in command procedures. It is a potential security risk. This example serves to show only the principles behind DIALOG.
! This is an example dialog file. It may be
! invoked from the monitor interface using the
! command:
! DIALOG filename [system]
! The command connects to the console of the
! specified system or systems then sends the
! specified strings and awaits the specified
! responses as though it were a user typing on the
! connected console.
! Valid commands within a dialog file are UNLOCK,
! SEND and WAIT. They are described in the example
! below. Lines with a ! or # in the first
! character position are treated as comments.
! This example dialog logs a user into a OpenVMS
! system.
! The RATE command sets the interval the DIALOG waits
! between SEND commands.
! This allows systems that are not able to do flow
! control properly to work.
! Set the interval in this example to 5 seconds.
RATE 5
! The UNLOCK command forces the console upon which
! the dialog is being
! executed to be unlocked i.e. any other connected
! users are placed into
! read-only mode. This command should be executed
! before the first SEND command. Otherwise the SEND
! command will fail if another user is connected to
! the console.
UNLOCK
! The SEND command sends the characters in quotes to
! the connected console
! as though a connected user had typed them. The send
! command always appends a carriage Enter to the
! quoted string. The command below is, therefore
! sending a carriage Enter to the OpenVMS console to
! get a username prompt up.
SEND ""
! The WAIT command causes the dialog to wait until a
! specified regular expression is seen on the
! connected console line. The first argument is
! a timeout in seconds after which the WAIT will
! terminate with an error causing the whole dialog
! sequence to terminate as well. A timeout value
! of zero causes an indefinite wait.
! The quoted string is the awaited regular
! expression. In this case we are waiting for the
! username prompt from OpenVMS.
WAIT 20 "Username:"
! Now send our username.
SEND "SMITHJ"
! Await the password prompt.
WAIT 20 "Password:"
! Send our password
SEND "SMITHJS_PASSWORD"
! Await the DCL prompt - give it plenty of time to get logged in.
WAIT 40 "$"
! Send any DCL commands you want executed here
SEND "SHOW TIME"
! This particular dialog exits leaving you logged in to the console.
