Modifying the Configuration Database › Using the DECwindows Motif Interface to the Configuration Editor › Saving the Contents of the Database in Another Binary File › Editing the Contents of a Saved Binary file
You can edit the configuration database that you have saved as a binary file with a different name. To do this, pull down the File menu and choose the Use... menu item.
Copyright © 2010 CA.
