Previous Topic: Editing the Contents of a Saved Binary fileNext Topic: Exporting the Contents of the Configuration Database
Saving the Contents of the Configuration Database in Text Format
You can save the contents of your configuration database to a text file and read the edited file back into Console Manager. There are two functions to do this:
This allows you to edit the contents of the configuration database using a text editor of your choice.
Also, you can import a file that was exported from a previous version of Console Manager This allows you to quickly recreate your configuration database in the new version.
Note: Binary files are not compatible across product versions, but import/export files are forward compatible, for example, an import/export file created on Console Manager r3 or V3.0 is compatible with r3.1. If you wish to use the configuration databasefrom a system running either r3 or V3.0, export the database, copy the exported file to the system running r3.1, manually edit any platform specific changes (for example, logging directories), and then use the Import... menu item. This feature is especially useful when you need to combine, in whole or part, configuration databases from multiple Console Management systems.
Note: If you are upgrading a system from either r3 or V3.0, the database is converted during the upgrade; it is not necessary to perform import/export to migrate your configuration database.
