To avoid accidentally starting Console Manager with an incomplete configuration database, the configuration editor allows you to redirect updated information to a file other than the standard configuration database. It also allows you to resume editing this file if it is only partially complete.
To save updates to the configuration database in a binary file with a name other than that of the default configuration database, enter:
CM Edit> save cm.dat
Copyright © 2010 CA.
