Modifying the Configuration Database › Using the Command Line Interface to the Configuration Editor › Saving the Contents of the Configuration Database In Another Binary File › Editing the Contents of a Saved Binary File
You can edit the configuration database that you have saved as a binary file with a different name. To do this, use the use command. For example,
CM Edit> use cm.dat
Copyright © 2010 CA.
